Topic: Help connecting ADAT to babyface
Hey all, having some trouble getting the ADAT working on my Babyface (not the pro).
I use my Babyface to record guitar and single mic stuff, so using the breakout cable, while no problem, is very space consuming and annoying to use. I recently got handed down a Behringer Ultragain Pro8 which was working where I got it from. I got an ADAT cable and mounted it on my rack, put the ADAT out from the Behringer to the In of the Babyface (red light was going into the babyface). I plugged my guitar into the Behringer and Totalmix does not receive any signal. I tried mostly everything, even taking a line out of the behringer into the Babyface breakout cable input, nothing. The Babyface still gets signal if I plug into the side guitar input or if I plug a mic directly into the breakout cable, but going ADAT through the Behringer gets nothing.
I am using a Mac Mini 2018 on Mojave. The Babyface model is the regular one, not pro. TotalMix v1.61. RME FireFace USB Settings at v223, firmware 3.16. Running my guitar through a Line6 Helix. Attached are my settings. I'm running the Behringer ADAT Slave.
Thanks!
