Topic: RME Babyface - output seperately through headphones?
hi!
I play live with pre-recorded tracks through my rme babyface (the older one) on a laptop
ideally I'd like to put my bass tracks through a bass cab instead of the pa
is there a good way to do it?
I use reaper as a DAW and the only options I see are to output a specific track through two hardware outputs which are used as left and right, if I could output it solely through the headphone output then that would be a good solution!
