Topic: upgrade to UFX II and trouble
I've been using the Fireface 802 for a couple of years now. Everything works perfectly. I recently upgraded to the UFX II in order to use the louder preamps. I downloaded and installed the latest drivers and connected it to my PC. After that I updated to the latest firmware.
Now that it's installed, my programs (Wavelab and Nuendo) can see and use the ASIO Madiface driver. However, windows 10 can't see it. If I try to play audio from a website like youtube, the PC can't find the audio. The little speaker icon in the tray has a red X, there is a error message saying "No audio Output Device is installed". I opened the PC audio settings and the UFX isn't available as an option. The device does appear in the device manager though.
I've tried uninstalling the drivers, using a different usb port, different usb cable and also a totally different PC.
Does anyone have an idea of what's going wrong here?
Thank you,
Peter
Re: upgrade to UFX II and trouble
The manual explains the Settings dialog and its option 'WDM Devices'...which are currently set to 0...
3 (edited by ramses 2019-09-14 16:55:08)
Manual chapter 7.2
Alternatively see also my blog about TM FX setup (step by step): WDM in particular -> point 11
https://www.tonstudio-forum.de/blog/ind … rnal-equi/
Also very helpful, RME tutorial videos
https://www.tonstudio-forum.de/blog/ind … al-Videos/
Thank you for the help. That solved the issue. I wonder why I didn't have to make this adjustment with the 802? I'm thankful for the help!
