Topic: Problem with interal recording.
Hey there.
I got a strange behaviour when i tried to record something from a dvd.
There is problem in all recordings like glitches (those you have when you use lower sample rate.)
I check SR to be @48K
Do i miss something here?
Re: Problem with interal recording.
do you record it with loop back of the outputs?
DC rules!
3
I would also like to hear more details about the record setup.
Nothing specific... just a record from W.Media Player while playback...
In "Input Device set up" of Digi are following:
Asio playback Device selected.
Channel Selected: Analog (1+2)
Prefered SR 48khz.
Set SR for Asio inputs : Uncheked.
5
So you played back a DVD via WMP and tried to record the sound?
Right... and all i get is a signal like open a file with wrong SR... full distorted...
Is WMP also playing back 48k? If not, select the correct Sample Rate in DC.
Its dvd the medium, so yes it pays back at 48khz
i try to record it with on board sound card and its ok in that.
of course the quality is ... big_smile
9
Recording of WDM sources is not supported at this time. The 'Output' can only hook on ASIO sources withpout errors. See online help, MME problem.
Ahh ok. I see.
Looking forward for a possible solution.
Thanks Matthias.
