1 (edited by undercode 2008-07-19 05:47:22)
Topic: Fireface 400 Manual glitches....
On the Fireface 400 manual, version 1.5:
Page 89,
"Microphone 1-2, rear"
Page 91,
"36.7 General
? Included power supply: Internal switching PSU, 100 - 240 V AC, 2 A, 24 Watts                                     <- 1
? Typical power consumption: 13 Watts
? Current at 12 Volt operating voltage: 910 mA (11 Watts)
? Dimensions including rack ears (WxHxD): 265 x 44 x 165 mm (10.5" x 1.73" x 6.5]")
? Dimensions without rack ears/handles (WxHxD): 218 x 44 x 55 mm (8.6" x 1.73" x 6.1")
? Weight: 1.5 kg ( 3.3 lbs)
? Temperature range: +5? up to +50? Celsius (41? F up to 122?F)
? Relative humidity: < 75%, non condensing
? Included power supply: Internal switching PSU, 100 - 240 V AC, 2 A, 24 Watts"                     <- 2
Someone might start searching Mic inputs on the rear and claim two power supply units... ; )
Cheers.
Fireface 400 + DIGI96/8 PAD. It's old but works.
Re: Fireface 400 Manual glitches....
Thanks.
3 (edited by undercode 2008-07-21 05:35:42)
Still missed the correct depth size correction. I marked only with bold so it slipped you aside. Sorry.
It's 155 mm, not 55 mm right?
Cheers.
Too late now. Maybe next time.
5 (edited by undercode 2008-07-22 04:31:08)
Here some more for the next time.
sorry if I didn't catch them all in one time:
Page 22;
11.4 Limit Bandwidth
Available Settings
All channels   (default) activates all 18 input and output channels.
Analog + SPDIF  activates all 10 analog channels plus SPDIF.
Analog 1-8  activates only the first eight analog channels.
(The Analog + SP + ADAT 1 - 4 needs to be inserted here, right?)
Page 95;
Limit Bandwidth - 48 kHz (18) - 96 kHz (14) - 192 kHz (10) - FW-Kkan?le
3 Firefaces at 96 kHz can't are not reliable at full channel count (3 x 14 equals 3 x 28 = 84
channels per direction). The Settings dialog might show errors, audio might distort.
To not exceed a maximum of 80 channels with 3 Firefaces at 96 kHz, a setting like Ana-
log+SPDIF is recommended to be used on at least one Fireface.
6
Superb! Thanks a lot!
8 channels... :-)
8 (edited by undercode 2008-07-22 16:45:11)
Ah... Nice... Slipped me that one :-)
That "To not" start of sentence is a bit strange... Is it correct? It makes half-sence...
I don't think it's incorrect, maybe "In order to not..." is a bit more elegant.
That's up to you guys. I'm just reporting. If you say that must be like that, who am I to disagree?
That one of the 10 analog outs passed by me like a rocket... damn...
11 (edited by undercode 2008-10-01 03:07:31)
After reading it another time...
Here some more corrections:
Page 17 on the manual:
Limit Bandwidth
Allows to reduce the amount of bandwidth used on the FireWire bus. See chapter 11.4.
(Analog + SP. + ADAT 1-4  activates all 8 analog channels plus SPDIF plus 4 ADAT channels)
  [missing]
Phones Level
Defines the reference level for the rear analog outputs 7/8.
Cheers.
