Topic: HDSP 9632 - White noise when playing back DVD in Windows Media player
I'm doing a new build for someone at the moment loosely based around a spec i've done before but i'm seeing a strange issue this time.
The spec has this in it:
Supermicro X8DTI
2 x XEON X5550 2.6 Cpus
24 GB Supermicro memory
1 x 512mb 9400gt GFX card
1050W Enermax Revolution psu
1x 500GB seagate
4 x 1TB samsung spinpoint
Vista Ultimate 64bit
I have a HDSP 9632 in the system.
When I play a dvd through windows media player all I get is static white noise. The volume control in media player has no effect on the sound but I can adjust the level of noise in the rme controll panel.
It's not distorted audio. It's pure noise that plays as long as the dvd video does regardless of noise being generated by the motion on the screen.
I've swapped in another RME card (same model) that i've been using personally for about 8 months and it replicates the issue.
I've resoftwared twice the second time with no other devices in the system and no change.
If I put a creative card in the dvd audio plays fine.
If I run Power dvd it's fine
If I run VLC it's fine
If I play back any audio through Windows media player it's fine.
It's just dvd audio and it's driving me nuts, and I can't ship the system to the client to I know what's going on with it.
I'm guessing either driver and hardware or codec in windows media player and something else?
Can anyone offer up any ideas?
Cheers,
Pete.
Re: HDSP 9632 - White noise when playing back DVD in Windows Media player
Hi Pete,
Seems like a DTS decoding problem. WMP does not decode, and neither does the RME card. VLC and PowerDVD do the decoding in software. If you route the output to SPDIF, check the "Non-Audio" box for SPDIF out, then connect the SPDIF out to a home theater receiver, it will work as the decoding will be done at the receiver.
I think you'll need this to use WMP DVD playback with the analog outs of the HDSP card: http://ac3filter.net/
Thank Jeff.
That looks like it's along the lines of what we were thinking and it all makes perfect sense. I don't have a surround amp to hand, but the client doesn't need to use that feature anyway, we just wanted to ensure it wasn't a symptom of a more serious issue.
Thanks for the quick response too.
Pete.
We are a small specialist system builder here in the UK and have a number of customers using the HDSP9632 along with the Ao4s card to provide analogue 5.1 output. This is mainly for Blu-ray playback via PowerDVD or Arcsoft?s Total Media Theatre 3 for customers that cannot take audio over HDMI. The multi-channel analogue output is an excellent 2nd choice.
For this to work you have to set the main system audio output in Control Panel ? Hardware and Sound ? Manage Audio Devices ? Sound Playback to ?Speakers? RME HDSP ? this works great however it also means that regular DVD playback in Windows Media Player/Windows Media Center is also via analogue multi-channel with the built in Microsoft Dolby decoder providing the multi channel analogue output (note it can?t do this for DTS but that is an accepted constraint).
This has all worked well until now, and we are now seeing the same problem as Pete Kaine has posted with DVD playback in Windows Media Center not decoding to analogue ? you hear white noise from the front two channels ? it?s as if the raw Dolby Digital bitstream is being output via the analogue front channels. 3rd party players like PowerDVD or the Arcsoft player still work fine.
We?ve done some troubleshooting to see what?s changed and it looks like Vista Service Pack 2 is the culprit.
On a test system with an initial build of Vista 32bit Home Premium SP1 and a RME HDSP9632 card with firmware 154 and WDM drivers 3.0.8.1 all works well. As soon as you run through all the Windows updates finishing with SP2 it gets broken.
We?ve tried HDSP9632 cards with firmware 153 and older WDM drivers 3.0.5.6 to 3.0.7.3 and the result is the same.
Incidentally the same problem exists with Windows Media Player/Windows Media Center in Windows 7 build 7100  ? we haven?t tried the final RTM version yet.
Whilst we can advise our customers to hold back from installing Vista Service Pack 2 inevitably this will not always be possible.
Is this something that can be fixed with an updated HDSP driver?
What about Windows 7 ? have you seen this problem?
Thank you in advance for your assistance.
Phil Hale
Uvem Ltd, UK
5
We will work on an update of the HDSP (e) drivers for better WDM integration, based on our experiences with the Fireface UC, which has the most/best support for 'Windows multimedia' ever. Unfortunately I have no date so can not say when this will happen.
Hi Matthias,
Thank you for the quick reply.
As I mentioned before with Vista we can try and stop our customers applying SP2 but with Windows 7 are you saying we will just have to wait for a driver update? If that is the case then we?ll have to look at alternative hardware.
Do you have any other product that will currently work with Vista SP2 and/or Windows 7 and provide 5.1/7.1 analogue output using WMP/Media Center as the DVD player/decoder?
Regards, Phil
7
Fireface UC.
Hi RME,
Has there been any progress in resolving this issue?
I can confirm that the latest WDM driver 3.082 made no difference with Windows Vista SP2.
Interestingly I?ve retested with Windows 7, both the RC7100 and the now officially released build 7600, and this now works with driver WDM 3.081 and the latest 3.082, I'm not sure what's changed and why it didn't work before.
Rolling back Windows Vista from SP2 to SP1 also restores things.
Thank you in advance for any update.
Phil
I've found a work around for 2 channel systems that others in the same situation may find useful.
In Control Panel - Hardware and Sound - Manage Audio Devices - Playback - Change the default output from Analogue (1+2) RME to SPDIF RME HDSP 9632
Select Properties - Supported Formats - deselect Dolby Digital - and Apply
In the HDSP Matrix ensure the S/PDIF output is also mapped to Analogue channels 1 and 2 (Out 3->AN 1 and Out 3->AN 2)
The system then decodes Dolby to 2 channel which the RME then outputs over analogue. This works with Vista SP2.
Obviously no good for 6 channel analogue output.
Phil
Is there any news on when/if an updated driver will fix the problem of WMP/7MC playback of decoded Dolby soundtracks to 6 channel audio with the HDSP9632+AO4S board.
To recap:
With Vista SP2 and all versions of Windows 7 (I?ve tested x86, x64 7HP, 7Ult), playback of a regular DVD video with Dolby soundtrack via analogue output:
In WMP12 you just get noise from the front two channels
In 7MC regardless of opting for 2 speakers or 5.1 speakers in the Speakers setup you only get decoded to 2 speaker output
In Arcsoft TMT DVD playback is fine through all 6 speakers
With Vista SP1 playback is fine  in WMP12 or Media Center ? the update to Vista SP2 broke things and this continues into Windows 7.
I?m guessing that Microsoft updated their internal Dolby Decoder filter (AC3) and this doesn?t work with the RME WDM driver (any version).
This is a major headache for a number of our customers wishing to use Media Center to playback DVD?s via analogue 6 speaker out.
Switching to the motherboard Realtek audio (up to 8 channels analogue) is an option but is clearly inferior to the RME HDSP9632+AO4S combination.
An updated WDM driver to restore things would be greatly appreciated.
Phil
Hello Phil,
Please Check if the update uses a different portcls.sys.
Another workaround you might want to try & should work, is setting a higher merit for an external filter such as AC3 Filter etc.
Hi, thanks for the suggestion - I was hoping to hear for an update from RME - I don't fancy tinkering with merits and external filters, much rather have an official solution.
bump
14
Can you please try driver version 3.083? It solved the problem on our systems.
https://archiv.rme-audio.de/download/hdsp_wdm_3083.zip
Hi, i have the white noise problem using my FF400.  i am using the latest driver which is currently 2.9992.  are you likely to be able to provide a driver update to fix the problem for this interface??
16
Will come.
