1 (edited by grema 2010-01-24 11:03:17)
Topic: Errorcode: FE7-D-0013
if you answer is possible in german, pls.
when i install my driver for the hammerfall multiface the red light is still on..when i start cubase or reason i get this errorcode: FE7-D-0013
there is also a text like: there is a problem with the connection to soundcard, pls restart the program or windows..if i do that, nothin happend.
askin for help..
Re: Errorcode: FE7-D-0013
Geht das HDSP-Settingsfenster auf?
(Does the settings window open up)?
mfg/Regards
ja alles ganz normal..
(yes, evrything normal)
also der genaue text wenn ich cubase oder reason starte ist der: die verbinndung mit der soundkarte wurde unterbrochen. bitte w?hlen sie "ger?te zur?cksetzen" im optionsmen? oder starten sie cubase oder eventuell sogar windows neu.
the installation is going fine...no errors nothing. when i reboot windows, the red light is stil on. when i go to audio settings there seems evrything to be ok! there are analog outs, i have choosen 1+2 for my monitors. evrything seems to be ok..
im thinking about that there is a windows problem maby?!
...when i open the settings, i see: I/O Box State: Error
ok, it works. the cable was  in the wrong slot on the pc..haha
Gl?ck gehabt... Dabei k?nnte das MF auch besch?digt werden...
mfg
