The entire TB2/TB3/USB3/USB-C situation is turning into a disaster.
Apple is quietly replacing the charging cable that came with the USB-C equipped Macbook for a new one. The type number isn't changed tho.
If you need one, buy one in a rectangular box, the old one has a square box.
In some circumstances (with some devices and some 3rd party cables) it results in a completely destroyed computer. With Macbooks and the new MB Pro, the USB-C will be damaged and only work intermittently afterwards, if you encounter this problem. Of course, this isn't much better than a destroyed computer, as Apple will charge for a complete logic board replacement as the ports are on the main board. I doubt if warranty will cover this, but we'll have to wait to see what happens.
Nobody seems to know what works with which adapter...
Some reading:
http://tidbits.com/article/16870
http://www.theverge.com/tldr/2016/11/8/ … re-macbook
http://www.theverge.com/2016/2/4/109162 … ower-cords
Remark that this isn't an Apple only problem. Other platforms are affected too and nobody can foresee what will happen with a specific combination of computer/adapter/device.
Let's all say "Thank you, USB Industry association"?
The worst part is that you can't tell what's in a USB-C port. It could fi contain TB3, but it might not. Pure joy!
