Topic: Short Some Output Channels on Multiface 1
This has been driving me nuts. I am running a Win10 64 Lenovo laptop with a PCMCIA card and cardbus 34 adapter. All works fine unless I enable more than 6 analog outputs in which case playback slows down, lowers in pitch and sounds "grainy". Windows seems to recognize the card just fine. Further, when I add a Presonus Digimax FS via ADAT I can use 6 of those outut channels or any combination of 6 between the two cards.
I have two Multifaces and two PCMCIA cards and any combination does the same thing. Everything seems to work fine on an older Lenovo laptop that has a PCMCIA slot and does not require the cardbus adapter. I would suspect the cardbus adapter if it didn't work at all but as it is recognized by Windows and by Reaper I think there might be another problem.
I have spent a fair amount of time the last few weeks checking forums and fussing with this and I don't know what else to do.
Any ideas? I don't want to part with my RME!
Re: Short Some Output Channels on Multiface 1
Can you obtain a native Cardbus HDSP card?
I believe those PCMCIA-to-Cardbus adapters don't play well with realtime/low-latency stuff like Audio.  I once used a PCMCIA-to-PCI adaptor with a PCIMCIA HDSP and it worked, but not as good (efficient) as a native PCIe HDSP card in the same PC.  I think going from parallel PCI (PCMCIA) to serial PCIe (Cardbus) is part of the issue there...
If not - any of RME's current USB interfaces should leave a classic MultiFace in the dust :-)  I still own a few MF1's myself - but the newer TM-FX interfaces are much nicer to work with IMNSHO (MF-XT + ARC over here)...
cool
2x SSL Alphalink MADI AX
make sure to disable PCie power saving in the BIOS and in Windows (full performance power profile), plerhaps that will help.
This is an Expresscard based adapter for a Cardbus card, right?
Thanks for your replies.
I have had my eye out for a cardbus 34 card. They are not available very often or are bundled with other equipment. I am reluctant to pay high dollar for one from Europe if I can't be sure it will even work.  Replacing everything with new gear, unfortunately, is not on the horizon.
Oddly enough the most stable setup I have is my older laptop using the cardbus adapter. Even though it has a PCMCIA slot as well, I can get all 18 channels open for record and playback using the adapter in the cardbus slot. For some reason I had to use an older driver for this to work.
My desire is to use the newer laptop as it has more horsepower, more memory and a 64 bit OS. The older one doesn't meet spec for some of my plugins and virtual instruments. I just am unable to get more than 6 output channels to work.
Thanks for your tip, Daniel. I had switched power saving in Windows but it was not an option in BIOS.
Thanks again.
Hank
