Topic: USB connection to Logitech touch
Dear all, did anybody manage to get the Logitech Touch working with ADI-2 Pro  through digital, i.e. USB connection ?
SPDIF obviously works fine (showing corect 44.1kHz) but connecting the Logitech Touch results in 768kHz int in the display and no output signal… I suppose this a „Kernel issue“ of the Logitech touch. Aries Mini USB works fine with the ADI-2 Pro though... Any hints?
ADI-2 Pro Anniversary Edition, Babyface Snow Edition, Auralic Aries Mini, Chord Mojo etc...
Re: USB connection to Logitech touch
Hi fonti68,
as far as I know the USB-Port of the Squeezebox Touch supports only HD-USB-Disks. If you want connect to your ADI-2 Pro, install 'Enhanced Digital Output' on your Squeezebox Touch. To do this go to Settings - Advanced - Applet Installer - Enhanced Digital Output.
See also this page:
http://forums.slimdevices.com/showthrea … ital-Ouput
Does anybody managed to connect a Squeezebox touch via USB to an ADI-2 DAC using the EDO Plugin?
I was not able, but maybe I missed something?
Thx
