UPDATE:
Good Afternoon Friends:
I received the new PCI Card from Sonnet Tech.
http://www.sonnettech.com/product/alleg … pcie.html.
I installed the card and there are no longer Pops and Clicks. However, I am running only about 10 Audio Tracks but with lots of Effects and Processing plug-ins.
I plan to run heavy projects soon.
I also ran LatencyMon before and after I installed the New Card and below is a summary:
I am not sure what's happening because this computers does not run any services or other programs, it's only for music.
How can a 64GB Intel QUAD Core with Dedicated NVidia 6060Ti not be suitable for Audio?
Before I started recording on this computer, I use to Run Photoshop and Visual Studio and every heavy system dragging software you can think of and it just chewed it all up.
I have already research that turning CPU Parking off can damage your CPU but I leave that to the expert.
But I do have Power to Maximum and like 10 fans in this Tower so it's cool.
Screen shot:
Full Report:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:56:43 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: WORKSTATION
OS version: Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
Hardware: ASUSTeK COMPUTER INC., SABERTOOTH X79
CPU: GenuineIntel Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
Logical processors: 8
Processor groups: 1
RAM: 61377 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Measured CPU speed: 1 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED KERNEL TIMER LATENCIES
This value represents the maximum measured latency of a perodically scheduled kernel timer.
Highest measured kernel timer latency (µs): 11706.620269
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 86.850
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.031399
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.036875
ISR count (execution time <250 µs): 1072619
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 505.435833
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 384.94 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.019083
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.047566
DPC count (execution time <250 µs): 4233698
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 16
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 4455
Hard pagefault count of hardest hit process: 1384
Highest hard pagefault resolution time (µs): 135740.890
Total time spent in hard pagefaults (%): 0.030965
Number of processes hit: 20
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1.749090
CPU 0 ISR highest execution time (µs): 2.695833
CPU 0 ISR total execution time (s): 0.099083
CPU 0 ISR count: 218174
CPU 0 DPC highest execution time (µs): 115.39750
CPU 0 DPC total execution time (s): 1.256335
CPU 0 DPC count: 813110
CPU 1 Interrupt cycle time (s): 0.044473
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 0.0
CPU 1 DPC total execution time (s): 0.0
CPU 1 DPC count: 0
CPU 2 Interrupt cycle time (s): 20.887755
CPU 2 ISR highest execution time (µs): 86.850
CPU 2 ISR total execution time (s): 9.664295
CPU 2 ISR count: 821316
CPU 2 DPC highest execution time (µs): 505.435833
CPU 2 DPC total execution time (s): 10.621663
CPU 2 DPC count: 2818282
CPU 3 Interrupt cycle time (s): 0.421070
CPU 3 ISR highest execution time (µs): 13.486667
CPU 3 ISR total execution time (s): 0.268726
CPU 3 ISR count: 32294
CPU 3 DPC highest execution time (µs): 41.969167
CPU 3 DPC total execution time (s): 0.093053
CPU 3 DPC count: 35126
CPU 4 Interrupt cycle time (s): 0.793223
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 15.830
CPU 4 DPC total execution time (s): 0.469039
CPU 4 DPC count: 294083
CPU 5 Interrupt cycle time (s): 0.058214
CPU 5 ISR highest execution time (µs): 10.138333
CPU 5 ISR total execution time (s): 0.007171
CPU 5 ISR count: 835
CPU 5 DPC highest execution time (µs): 14.929167
CPU 5 DPC total execution time (s): 0.000898
CPU 5 DPC count: 872
CPU 6 Interrupt cycle time (s): 0.045636
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 0.0
CPU 6 DPC total execution time (s): 0.0
CPU 6 DPC count: 0
CPU 7 Interrupt cycle time (s): 0.845728
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 15.446667
CPU 7 DPC total execution time (s): 0.509114
CPU 7 DPC count: 272241
