Topic: XTC autoset gain in stereo.
I'm slowly getting to grips live recording with the UFX / XTC combination.
I have a question about using autoset gain for stereo channels when remote controlling the XTC via MIDI- and wanted to see if anyone else had any advice.
On the UFX everything works just as I'd expect - autoset gain adjustments adjust both stereo channels.
On the XTC - the stereo autoset gain is controlled with groups (or at least that's how I think I should be doing it). (These can combine more than 2 channels if needed - although I'm only using them for stereo).
However using groups means that I can't toggle the `group` autoset gain on the channel - just the `single channel` autoset gain.
How do others set up stereo channels and autoset gain on the XTC when using TotalMix FX to control it?
Re: XTC autoset gain in stereo.
Hi
I am searching for exactly this. Since your post is already 3yrs old i want to ask if you did find a solution?
I decided not to use stereo auto set via TotalMix on the XTC channels, and just use groups via the front panel.
4 (edited by waedi 2021-11-13 18:45:47)
https://ibb.co/cxB0hXM
Please focus on bottom right corner.
https://rme-audio.de/downloads/midiremote_mac.zip
https://rme-audio.de/downloads/midiremote_win.zip
MIDI remote is great - but you can’t have it running at the same time as TotalMixFx (they can fight each other).
I depend on TotalMixFx for headphones mixes etc, so just find it easier to use the UFX buttons.
Ah ok, thanks for that, good to know.
Glad you find a way to work.
