Topic: DIGICheck not compatible with "Set 'ASIO devices" feature
using the "Set ASIO devices" (a feature that was introduced with the latest drivers to sort your ASIO I/Os if you have several RME interfaces connected) seems to heavily confuse DIGICheck. In fact, the signals are shown at the completely wrong I/Os. That is especially critical with Global Record.
Re: DIGICheck not compatible with "Set 'ASIO devices" feature
That is a known issue, sorry. This new feature needs updates in TM FX as well as DC, which will be done at a later time.
Thanks for the info, Matthias.
if I connetc UFX and UFX II at the same time via USB, Digicheck 5.91 shows both interfaces, but I can only select UFX to Monitor.
If I choose Madiface, its accepted and I can choose inputs , outputs but they are not shown in Digichck 5.91, ist falls back to UFX.
This may be the same issus as reported above.
Note: I use now Totalmix V1.43 (because it installs with the driver), Driver UFX 1.099, Driver UFX II 0.9.616.0
