Topic: DAC as Audio Interface ?
I want to build a dedicated PC for electronic music production. It will be 100% digital affair "in the box", so no mics, no analog inputs, no external instruments or FXs - just VST plugins within a DAW (Ableton 10).
Also, I want to have ADI-2 Pro as an "endpoint" to monitors.
So here is my quandary: Should I put some kind of Audio Interface between the DAC and PC, or I can use ADI-2 Pro as de facto (USB) Audio Interface ?
I don't have many experience in all this, and none with RME gear, so I wonder if I'm missing something here (if using ADI-2 Pro standalone), like TotalMix software - is it crucial to effectively using a DAW...? And ADI's ASIO - is it "friendly" enough for a DAW duties...?
I'm sorry for newbie questions, but I tried to google this already, and found very few answers, all very vague and ambiguous.
Thanks.
Re: DAC as Audio Interface ?
For your application the ADI-2 Pro is 100% qualified. No TotalMix needed.
Thank you sir !
You will either need active monitors or a power amplifier. You should not need a pre-amp because the ADI-2 has a volume control and very configurable output range.
