Topic: Confused about di boxes
Hi
I have a multiface ii
I want to plug in 3 guitars
Electric
Bass
Electric/acoustic
I'm wondering what do boxes I would need for these?
Are the inputs on the multiface line level, so I would need to get a di box that outputs line level?
I need to get hiz inputs on the di too
The thing I find confusing is that all the do boxes seem to be outputting mic level.
Is there any recommendation for a cheap Di box or 3 to plug in my guitars?
I've been looking at the LD ones but again they're mic level?
Confused.
Would be grateful for any help.
N
Re: Confused about di boxes
DI boxes tend to be mic level, because that's the most common stage implementation.
3 (edited by newt 2018-09-12 06:29:47)
Thanks.
Although this is where it gets confusing for me, because on this thread it says about the multiface:
https://www.forum.rme-audio.de/viewtopic.php?id=9403
The Line inputs can also be used as instrument inputs. Active instruments can be connected directly. Passive
e-guitars require an additional impedance buffer.
Does this mean that I can just get a normal di box (that goes from hiz to mic output) for the passive guitars and it will be enough for the multiface?
I plan on using some VST amp modelers so will use those to add gain.
I'm wondering will this be enough?
