Topic: Platform M+
Hello
I'm trying to control Totalmix with an Icon Platform M+
it doesn't work at all.
I'm using total mix to monitor 8 inputs before recording stuff in my DAW, and I need to physically control MUTE and VOLUME inputs for monitoring during recording sessions with musicians
1st / In the TM Options > Settings
Midi Connection Input & Output settings doesn't remember my selection (in my case Platform m+)
When I close the window and reopen it, my selection is gone, back to "none"
2nd / I'm using IconnectMIDI4, so I can use a virtual midiport to redirect platform's midi input and output data.
So I succeed to control TM HARDWARE Outputs Volumes, but the controller is receiving weird data so it still doesn't work.
I tried Platform in ableton live with "mackiecontrol" settings  and everything is working perfectly.
Is there anyone who's using some Icon's controller with Totalmix who can share experiences ?
Re: Platform M+
Update/Fix: On Mac, TotalmixFX will automatically reject the default device. In this case, "Platform M+ V2.05".
-In MIDI studio, Create a new device, name it whatever you want. (e.g. 'Platform M+')
-Connect/Join the "Platform M+ V2.05" to the new created device.
-The new device will then be seen by and work with TotalmixFX.
https://i.ibb.co/Qn4Hrx9/Screen-Shot-2020-02-27-at-14-35-13.png
Re: Platform M+
Thanks Mark - this was confounding me until I found your post!
Eastwood Records
www.eastwoodrecords.co.uk
Re: Platform M+
Many thanks for this workaround. Did you manage to switch between TotalMix Sections (INPUT, OUTPUT..)?
I followed this instructions: https://www.youtube.com/watch?v=hlvNrb2W0Oc but this won't work.
After changing the MIDI assignments of the buttons and upload to the controller i'm able to switch between sections but the faders aren't working anymore....
any suggests?
Thx in advance
