Topic: RME ADI-192 DD - Dead LED?
Just got a used ADI-192 DD and upon turning it on all the LEDs turn on except for the QS LED in the range section of the SRC input. Is that normal? Shouldn't all LEDs turn on when you power up?
Thank you
RME User Forum → MADI/AES Premium Line → RME ADI-192 DD - Dead LED?
Thank you
I can't check that. But you can apply a 192 kHz AES signal (simple: loopback, internal clock) then you know if the LED is defective or not.
I did that and when i do, I get the DS and QS in the monitor section ON but the QS on the SRC input is OFF.
I see. The SRC input range is a manual choice (manual page 24). If you can't activate the LED by pushing the Select button then the LED seems defective.
