1
Topic: Firmware Updates ADI-2 Pro 185 / 90 and DAC 26 / 25
Well, we were close! And the plan worked - releasing the firmware some time before Christmas we would be able to react early enough in case we overlooked something. Then, between Christmas and New Year, you could finally do what you always wanted to do - play around with the Pro and DAC and enjoy all its exciting and addicting functionality in full glory!
Which brings us to a small update, firmware 90 (Pro) and 25 (DAC). Here are the news:
- The new feature 'Do not Show Vol Screen' also made the Bass & Treble screen disappear. Fixed.
- Feature change: the PEQ's Q value can now be dialed up to 9.9 (instead of 5.0) in bands 1 to 3.
- DAC only: The Bit Test was shifted to the next level. Fixed.
Firmware downloads:
Win:
http://www.rme-audio.de/download/fut_madiface_win.zip
Mac:
http://www.rme-audio.de/download/fut_madiface_mac.zip
Windows: If you need to install the driver and uninstall it again:
https://www.forum.rme-audio.de/viewtopi … 81#p135881
Enjoy and have a great time!
Re: Firmware Updates ADI-2 Pro 185 / 90 and DAC 26 / 25
Many thanks for this update and enjoy X-mas time smile
BR
Ramses
Win7 Prof, CubPro9.5, UFX+, XTC, ADI-2 Pro FS/DAC, RayDAT, ARC USB, Sonnet USB3-PRO-4PM-E
Hi MC,
just updated the Firmware, RME ADI-2 PRO FS Black, and the chance to dial the Q in the EQ settings keeps being 5 as the maximum
May I be doing something wrong? :
https://drive.google.com/file/d/1rUn3O- … sp=sharing
thx
Enrique
No, you do it correct. The description is not accurate. The new option is only available for bands 1 to 3, mainly for bass room problems. This is a technical limitation and will not change. I will update the text.
Understood, Thx MC
Same reason why only band 1-3 can go below 200 Hz?
7
Correct.
8 (edited by Nativebon 2019-03-11 12:19:06)
Hello Just need to find out the latest firmware version for the RME ADI-2 DAC.Form what I can see seems I currently have version V25.  I'm getting a second of sound or so cut off playing music. Not sure how to handle this.
