Topic: RME FF800 Adat showing and locked but no audio out!
Having a strange problem with my circa 2012 Mac Pro. Running the last version of High Sierra with a my FF800 autosynced to a Saffire Pro 40 at 48khz on ADAT 2 (ADAT cable snapped off in ADAT1 port so that's not useable). ADAT 2 light is green on FF800 front and not intermittent. I'm getting signal in Totalmix and audio on my DAW from ADAT in but only getting a signal on Totalmix for ADAT out! When I use the the Saffire as the main interface plugged via firewire the audio out works fine. Any ideas? Recently moved over the high sierra from whatever was before and that's pretty much the only thing that has changed in my setup. Anything I'm missing here?
