1 (edited by mattrixx 2019-05-21 01:54:13)
Topic: ARC USB footswitch polarity prob.
Hi there,
In the ARC USB manual, it mentions that you can use either a normally open, or normally closed switch.
However, when using any normally open F/S, results in the Talkback function being active on release.
I have tried powering on with connected, activated...etc etc..
Have I missed something?  I would really like to be able to use my normally open (momentary foot) switches.
Matt
Matt McKenzie-Smith
Re: ARC USB footswitch polarity prob.
Did you change the switches function between 'Enable' and 'Disable'?
3 (edited by mattrixx 2019-05-21 07:42:42)
Hi Matthias,
Yes, tried all settings.
(with my normally open foot switch)
Toggle is the only one that switches between TB on & off,
All of the momentary options result in the Talkback ON, when releasing the foot switch, with the exception of disable, which does nothing except over ride the front panel button if depressed.
(so in the meantime I am using a rather large Roland Damper that has the option for normally closed... this works)
It all works as per normal with my older ARC and the same footswitch (I had modified the ARC some years ago with a foot switch option...plus I can add a "client" switch with a y split adapter which works great).
I'd love it tow rod properly, so I can use both the normally open f/s and the button on the panel in Push-or mode... It's got me stumped.
BTW, due to cable limitations, I have the ARC USB connected via USB to the computer (if that makes a difference??)
Matt McKenzie-Smith
I'll check.
5 (edited by mattrixx 2019-05-21 07:49:22)
Thank you sir.
oh BTW.. MacOS 10.14.5
Matt McKenzie-Smith
Hi Matthias,
Just wondering if you 've had a chance to check it out?
Matt
Matt McKenzie-Smith
7
We did and hope to have this changed in the next update.
Thanks again Matthias!
Matt McKenzie-Smith
9
Please check the new option 'Push Off' in beta 4:
http://www.rme-audio.de/download/totalm … _161b4.zip
10 (edited by mattrixx 2019-06-06 02:04:52)
Thanks Matthias.. That is perfect!! :-)
Matt McKenzie-Smith
