sam_saw wrote:So the Tech Specs in the manual and on the RME website since the unit was introduced have been wrong all this time ?
No. Your quote refers to the line outputs. These have an internal DC-coupled signal path, they don't use a single capacitor in the signal path, except for a protection one directly at the output. Having no other capacitor in the whole circuit from DAC over level stages to the balanced output stage was not common practice when the FF800 was released. The phones outputs do not hacve such a capacitor at the output but before the volume pot to prvent scratch sounds when turing the pot. That said the FF800 was never advertised as having a frequency response down to 0 Hz or being able to send out DC.
sam_saw wrote:So if the 800 has no DC coupled anything i am potentially damaging the 'headphone out' with my testing of Voltage output ? I've sent sustained CV and LFO in testing, reading over 5 Volts with LFO.
You can generate and send out any signal you like, you can't damage such electronics this way. They only send out signals that they can handle. It's that easy.
sam_saw wrote:The .pdf you posted is not clear to me. What's NR.CH ?
Number of channels.
sam_saw wrote:What's the difference between a - and an X ?
- means not supported, X means DC supported.
