Topic: Latencey in Ableton 10.1
Hello
I find that the Digiface is not reporting the correct latency to Ableton, it's quite a lot out, some 100ms
www.yila.co.uk
2 (edited by ramses 2019-07-12 21:22:08)
Re: Latencey in Ableton 10.1
Could you deliver some useful information like:
OS, OS version, RME Driver version, sample rate, if Windows: ASIO buffersize, screenshot showing latency values.
BR
Ramses
X10SRi-F, Win7 Prof, Cubase 9.5, UFX+, Octamic XTC, ADI-2 Pro FS BE/DAC, RayDAT, ARC USB
OSX, NEWEST, NEWEST, 48, buffer reports 11ms, but when live compensates
www.yila.co.uk
Digiface is reporting the correct (its own) latency to the OS. Whatever you have attached to the Digiface is unknown and not the DF's problem. And whatever plug-in you might have inserted into the Master section, causing such a high latency, is also not the DF's problem.
5 (edited by iamyila 2019-07-15 18:46:10)
But plugins are compensated so their compensated latency is 0?
Then the only other latency is my converters via adat? What kind of numbers am I looking at there?
One ADI-8 DS Mk III
Two focusrite clarett Octo pre mk3
One babyface pro
And total mix latency too?
www.yila.co.uk
Check again with an empty project, you must have some plugin adding latency on the master output. TMFX latency is 3 samples. ADI-8 DS mkIII is 12 samples each way. Should be something like 4 ms round trip all added up.
7 (edited by iamyila 2019-07-17 12:03:14)
Ok, will do
are you saying that the Master plugins do not delay compensate?
also what is the correct way to calculate exact latency one way? 1000/ (48000 / 3) for the totalmix?
So this chain
Ableton audio out > Totalmix > Digiface > RME Babyface Pro > Totalmix > to headphones.
Mic > Babyface > Totalmix > Digiface > Totalmix > Ableton
www.yila.co.uk
Ok i tested again.
Master Plugin has no effect on recording compensated latency, that is compensated by Ableton.
One Rogue plugin (soothe) updated and fixed latency reporting
Those numbers were helpful but I'd like to work them all out accurately for each chain. Adding 4ms to the driver compensation has helped (for that round trip number you gave) - but what is the correct math? - it's hard to find numbers from focusrite.
Also adding 4ms to each hardware insert in Live.
I think what was happening was that I was getting accumulative latency, so couple of hardware inserts - Send and receives + the convertors plus totalmix was adding up.
www.yila.co.uk
Further testing reveals (using Reapers Reainsert ping function)
From Digiface via ADAT round trip latency >
Adi-8 DS Mk3; 24 samples
Both Focusrite Clarett Octopre; 47 Samples
Babyface Pro; 3 Samples
www.yila.co.uk
