Topic: Simulating inputs with digicheck playback.
Is there a way to have digicheck playback a recording so that the playback is routed through the inputs? I use a 3rd party app to mix live sound with and it would be awesome to use digicheck to record a sound check and then use the recording to playback the recorded soundcheck (ie: a virtual band) so I can further adjust EQ and Dynamics on my mixing app.
2 (edited by laex 2009-05-25 21:12:15)
Re: Simulating inputs with digicheck playback.
Yes, you can... The feature you're looking for is "loopback" within Totalmix... Watch those videos and a lot will be clearer...: http://www.rme-audio.de/forum/viewtopic.php?id=5039
I'm curious: What software do you use for live mixing?
Thx, laex
DC rules!
I'm using Software Audio Console - http://www.softwareaudioconsole.com/
Thanks.
I did some searching on the loopback function and I've seen some reports that it doesn work with the HDSP 9652 cards, which is what I have. Is this true?
Yes, the HDSP 9652 doesn't support loopback.
That's too bad.
Thanks.
use one of ADAT ports to loopback in by hardwired toslink, then Totalmix to route I/O's
just a piece of cake
100% versatile
HDSP9632, HDSP9652, ADI-8QS, FFUC, Quadmic II
Yeah, I suppose that would work. I was hoping to not have to unplug / replug cables.
