1 (edited by Stevie 2018-01-15 19:12:32)
Topic: TotalKeyMix 1.0 released - Windows volume control for TotalMix
I proudly present the release of TotalKeyMix! It's a tool to control the main volume of TotalMix with hotkeys (Windows only).
You can find the download and installation instructions here:
http://www.stephanroemer.net/stuff/tota … eymix.html
EDIT: I redesigned my website and since I hadn't seen much interest in TotalKeyMix (and also because I'm not using it anymore), I have removed it. However, I provided the original source code to Ikonomov and he recompiled it with an older AHK version and posted it here: https://autohotkey.com/boards/viewtopic … mp;t=42686
So, feel free to grab it there and even modify it to your needs!
Re: TotalKeyMix 1.0 released - Windows volume control for TotalMix
Wow, thanks for the sticky! smile
There will soon be an update that fixes the "full volume" issue on Windows startup.
Thanks a lot, Stevie!
Really useful stuff.
Now I can use TotalKeyMix on my older card the same way like having a Remote Control:
"Features Fireface UFX
The Remote Control is the perfect partner for the Fireface UFX. The unit allows to control the most important monitoring functions:
- Volume control of the main output and both headphone outputs (switchable)
- DIM (user adjustable value)
- Recall and store of a reference level for the main outputs (user adjustable value)
- Left button (Prog) is programmable and can control functions like Talkback, Speaker B, mono etc.
What I still miss is a reference level switch. Hope you can extend your work on that feature sometime.
Anyway, great job!
Can't wait for the bugfix.
Hi, thanks for the program. I'd like to request a new feature, make the talkback button assignable to a keyboard shortcut as well. I really need that and I don't want to buy a midi controller for that one function...
If this is already possible somehow with autohotkey and MIDI Yoke, a step by step guide would be greatly appreciated, and can't seem to make heads or tails of it! :roll
Hey guys!
As usual, time is too short to work more on TKM :roll but I will keep that in mind for future releases.
Cheers,
Stevie
Is there an an alternate for midi yoke ?  I'm using windows 7 64 bit. and it won't install:(
You could actually use http://nerds.de/en/loopbe1.html or http://www.tobias-erichsen.de/loopMIDI.html
Thank you very much Stevie smile
You're welcome smile
This application is wonderfull! I like it! I've a question: How I can choose the totalmix channel ? I can control only the first pair of channel. (1-2). In can control channel number 3 , or 4 or 5 etc.. ?
Yes, that's right, you can only control the main out.
sad
Thank you Steve!
Sorry, if my time would permit, I would include more features hmm
I'm working on a project where I'm intended to play and record at specific times automatically. I haven't still decided if the babyface or a HDSP card is the best option. In any case I need to use a Windows Pc and command the card remotely. I wonder if you have any SDK, libraries or any tool wich would make this posible for a developer.
David Hernandez
Hi!
This looks realy usefull. However, I can't get it to work on the Main control room out (or any hardware output either). The only fader in Total Mix I'm controling is the hardware input faders.
I tried to change this line in the xml-file:
<Keys>
                <F7 Modifiers="Shift,Control">NoteOff, 1, 53,0</F7>
</Keys>
Accoring to the UFX manual a cc volume change should do the trick. But I cant figure out how. Can any one lead me on the way?
/Johan
Is there any alternative solutions for OSX 10.8+ ?
Rme Ucx + Arc
Unfortunately this link is dead now sad
i7-4790k CPU | Asus Sabertooth Z97 mk1 | Corsair DDR3 | RME UFX | REAPER (latest beta) | Win8.1x64
Can anyone host this or does anyone know of a working mirror? I have tried every link I could come by through google to no avail.
Hi, I have a copy of TotalKeyMix 1.0
But I don´t know if it´s okay to share ...
BR Thomas
Multiface, Digiface, Raydat
If you will, you can send it through email. I can PM my email address.
HDSP9652+ADI-8AE  2X HDSP9632
Cubase pro10
YEP!
23 (edited by ikonomov 2018-01-12 06:32:27)
Edit: Please see post #25 below for an updated download link.
The download link by Stevie in the first post is dead.  It was archived by the Wayback Machine however.
web.archive.org/web/20161102235028/stephanroemer.net/stuff/totalkeymix/totalkeymix.html, including a download link of 1.0.2b version which according to the readme fixes the problem with the stored volume level at start up
web.archive.org/web/20160508042407/stephanroemer.net/resources/download/TotalKeyMix_v1.0.2b.zip.  Here is a post by Stevie with the script autohotkey.com/board/topic/17212-midi-output-from-ahk/?p=292047.
24 (edited by Stevie 2018-01-11 23:17:31)
Hey guys, sorry for not writing here for a while. I re-did my website and I thought there was not much interesst in TotalKeyMix (with all the iPad tools like Lemur and TouchOSC out there), that's why I didn't put it on my website anymore.
I'm completely okay with it, if you modify/share the script!
25 (edited by ikonomov 2018-01-17 02:21:30)
Stephan was kind enough to respond to my email and provide the source code and give the permission to re-post his files.  I uploaded a .zip file at the AutoHotKey forums with the source code, compiled .exe, his original instructions and a short updated readme to get things working on newer versions of Windows.
https://autohotkey.com/boards/viewtopic … mp;t=42686 (EDIT: This is the same link in the now updated first post of this thread)
26
Thanks! This will sure help some users!
27 (edited by ikonomov 2018-01-12 05:24:10)
I find it indispensable and wish I've found it years ago.  It allows me to control the volume of my monitors with an MCE remote controller.  It should also work with most standard remote controllers for windows.  It makes all the sense in the world to separate the windows volume from TotalMix, but ever since I bought my Babyface I've always wished to have another way to control the volume (without a MIDI controller).  Huge thanks to Stephan.
In this related post https://autohotkey.com/board/topic/1721 … ntry292047
I see an information "You need to have MIDI Yoke installed"
What is MIDI Yoke ?
BR
Ramses
29 (edited by ikonomov 2018-01-12 09:09:22)
What is MIDI Yoke ?
Hi ramses, I assume you have visited the old links I provided in my first post.  I posted an updated download link with instructions how to get things working at post #25 above (https://autohotkey.com/boards/viewtopic … mp;t=42686)  Download the .zip file there, unzip it and read readme.pdf and then readme_2018.pdf.  It was fairly simple and straight forward to get things working here.  Give a shout if you need some additional help afterwards.
I updated the original post with the info, thanks ikonomov for doing this!
Thank you Stevie for updating your original post with the new link.  I just uploaded a new version that allows easy customization of the speed of the Volume Up/Down buttons through the config.ini file.
Version 1.0.5 released with Volume On-Screen-Display!
Hello friends!
I have been interested in TotalKeyMix for about 4 years. Thank you all for collaborating for this great cause!
I found version 1.05 yesterday that includes some improvements and I love it. I keep this thread in favorites smile
Thank you!
Hey, I'll take a small credit for the improvements and thank you for the compliments.
I have updated the readme inside the download file found on the AutoHotkey forum with a workaround for a problem I found that prevents system standby.  The issue has been reported here https://www.forum.rme-audio.de/viewtopic.php?id=26684, hopefully in time it'll be resolved, but for the time being the workaround seems to work fine.
Excellent! Thanks a lot, Stevie! And also thanks to you ikonomov.
Great works are performed not by strength but by perseverance.
36 (edited by ikonomov 2019-02-21 02:03:27)
Recently I had to reinstall Windows, along with TotalKeyMix, and while reading the .pdf files I realized that I should rewrite the readme file with easier to follow instructions.  Additionally I made a few minor changes in the script and uploaded a new version 1.1.
Edit: I re-uploaded the v1.1 again with an edited readme.pdf.
37
THANKS so much for this solution!! It works perfectly together with my logitech g810 volume control. You guys are awesome!
